January 28, 2006, 11:37 |
Heat exchanger!
Hi! I'm simulating a 2D annular heat exchanger with two flow zones(with different fluid zones) in axial direction divided by a steel wall.
The heat exchanger is working in counter-flow and I have serious problems with the continuity convergence. I think that the reason for the problem is that I'm simulating very different fluids (the inner fluid is a non-Newtonian fluid and the external fluid is water) and Fluent tries to solve two different systems in one solver getting a poor solution, specially in the velocity field (when I display velocity contours, I don't get a real solution). Can anybody help me? I think that a possible solution can be to impose a UDF boundary condition of velocity in the entire external flow zone(water zone) so that fluent only has to solve the non-Newtonian flow, but I'm not sure if it will work. Can anybody give me more ideas? or tell me about his/her experience in similar problems. |
January 29, 2006, 02:27 |
Re: Heat exchanger!
Find what fluid is important to you and solve only it with the solid body and define a constant BC on the other side of the solid. It is not the same but is close to your case.....Hope I was clear....write if you find solution....
Heat Exchanger Model | sak2129 | FLUENT | 3 | September 26, 2017 01:29 |
Macro Heat Exchanger not selecting (Please help!) | zdeth | FLUENT | 2 | September 11, 2012 13:52 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
Heat Exchanger Simulation | tightaznbreaka | FLUENT | 0 | March 18, 2010 15:45 |
