October 3, 2007, 15:36 |
Using Fluent to simulate droplet impact
Currently, I am using Fluent to simulate 2D liquid droplet impact onto rigid surface. The droplet is 2 mm in diameter and 2 m/s. I used implicit, VOF scheme. Though the simulation works, but the results is far from the experimental results and disagree with the physical meaning. For example, with 2m/s droplet, it took 10 ms to travel 1 mm in the simulation, this result disagrees with the real physical result that should be 0.5 ms. I tried set the velocity to both absolute and superfacial, but they show the same results. Is there anyone has the exerimence of simulation of droplet impact can help me?
Thanks J |
May 29, 2011, 16:17 |
Monty
Rep Power: 14 |
Hi Jay..
Can u help me please about droplet simulation through pipe using vof model.. thanks |
June 13, 2015, 11:39 |
droplet impact on solid surface
#3 | |
aysan
I am already trying to simulate droplet impact on a solid dry surface, but I have major problems. would you please help me by introducing the related and helpful tutorials? Thank you, |
June 13, 2015, 12:04 |
#4 | |
aysan
May 27, 2016, 00:08 |
droplet impact
tawfiq
Rep Power: 12 |
Hi
I'm also trying to simulate droplet impact on solid surface with vof (dynamic mesh) but the droplet didn't move, although I give it 2 m/s as velocity. Could u please help me? thank you |
droplet impact on a dry surface.... VOF again | rogerspass | FLUENT | 1 | June 27, 2016 02:12 |
can FLUENT simulate the liquid film thickness | fadhil | FLUENT | 1 | March 11, 2009 06:48 |
simulate droplet oscillation | springdong | Main CFD Forum | 4 | March 25, 2005 11:07 |
help on domain size that Fluent can simulate | zwdi | Main CFD Forum | 0 | March 13, 2004 22:32 |
help:how can I simulate a flame in the fluent? | amir ghavidel | FLUENT | 0 | May 15, 2002 04:28 |
