Adaptation failing in // Fluent case?
Old   February 3, 2006, 14:57
Default Adaptation failing in // Fluent case?
Riaan
Hi all,
I am trying to adapt by Y+ to get my turbulence model in the correct range. The case is large, and is run on 6 computers in parallel.
When I do the Y+ Adaptation, it marks the cells, but does not display them, and when I click adapt, it does not adapt anything.
If I load the case onto a single computer, it displays the marked cells for adaptation, and goes ahead and adapts it - but fails because I am out of memory.
Why can I not adapt Y+ in the parallel case?
Thanks Riaan
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
fluent case n data files not exporting to tecplot krishna FLUENT 2 February 17, 2007 23:24
Case in Fluent Tutorial 1 Lam FLUENT 0 August 24, 2004 11:25
Fluent adaptation procedure wassim FLUENT 0 June 11, 2004 14:12
Fluent case file into Gambit Eric R. FLUENT 7 July 17, 2002 14:11
