What's the best program on building a 3D model |
February 20, 2006, 14:40 |
I have project that needs CFD modeling inside a complex 3D object. The object is so complex beyond the graphic capability of Gambit. I'm thinking of using some program like Autocad or Pro/E to create the drawings first, then import them to Gambit. I couldn't decide which program to use. I'm familiar with 2D drawings in AutoCad, and used Pro/E only a little. Can someone help me decide which one is the best to perform this task? Thanks in advance.
February 20, 2006, 15:13 |
Re: What's the best program on building a 3D model
For 3D modeling Pro/E is much stronger and more versatile than AutoCAD. Pick up a tutorial book on it. It's pretty easy to learn if you have some 3D modeling experience.
Good luck, Jason |
February 20, 2006, 20:01 |
Solid work is also okey.
February 21, 2006, 08:21 |
SolidWorks is by far the easiest modeling package I've ever worked with, and it's reasonably powerful. If you have the option, I would go with SolidWorks, but between Pro/E and AutoCAD, I recommend Pro/E.
Jason |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 10:36 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
simulation results for k-w model and SST model | Li | CFX | 7 | June 29, 2007 04:19 |
Large eddies at top of building using FLAIR | Peter | Phoenics | 2 | April 28, 2007 06:07 |
Kato-Launder model | sam | Main CFD Forum | 13 | September 21, 2006 10:15 |
