February 26, 2006, 12:44 |
spicies in mixture
hi averyone who read it. I`d like to make an mixture in "materials" panel but there is only fluid and solid to choose in "Material Type". On Fluentusers web I`ve seen that they can choose "mixture". Haw to do that? What to mark before to be able to have "mixture", "solid" and "fluid" in this place?
February 26, 2006, 18:15 |
Re: spicies in mixture
define Multiphase and then active the model you wish to use
February 27, 2006, 06:35 |
Ok Thank you very much
February 27, 2006, 14:30 |
Nice to know someone who knows how to say thank you, anyway my comment should be read as follows define-> models-> multiphase and then activate the pertinent mixture model. You are also advised to read Tutorial 18
February 28, 2006, 01:28 |
thank you one more time. I will check it. I`ve check last you sggestion (i did`t reed tut18. I will do it after this email) and first thing I see is a can`t see (can`t choose) any solid spicies under Materials/mixture/edit. There is only gas and fluid. I`d like to do a salt solution (NaCl+H2O) to be able to have salt cristals after water evaporation. I will ask my support engeener for help aboute it too. regards chem
mixture mass continuity eqn v.s. volumetric mixture continuity eqn | kaifu | ANSYS | 0 | June 9, 2011 08:42 |
mixture mass continuity v.s. volumetric mixture continuity in pressure equation | kaifu | OpenFOAM | 0 | June 9, 2011 08:14 |
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC | richpaj | OpenFOAM Bugs | 2 | October 9, 2008 22:14 |
Variable composition mixture .vs. reacting mixture | Ting Wen | CFX | 0 | January 7, 2008 06:04 |
Burning a CH4-H2 Mixture | Jonathan Lemay | CFX | 2 | November 12, 2007 17:01 |
