UDF in batch mode
Old   February 28, 2006, 05:47
Default UDF in batch mode
Bogdan
Hi everybody, I'm trying to includ a UDF function at BC, everything is going well in GUI but when I submit the job to PBS I get the error: "Error: chip-exec: function "unsteady_pressure" not found." There are special commands to be included in the script file? Thank you for your answer Regards, Bogdan
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 08:00
Running fluent with udf in batch mode zonexo Fluent UDF and Scheme Programming 2 March 10, 2012 07:50
DPM model in parallel batch mode Prashanth FLUENT 2 March 6, 2009 07:54
A Loop problem when running UDF in the batch mode Jun Geng FLUENT 3 July 16, 2008 08:34
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 06:49
