March 1, 2006, 09:51 |
Help with particle diameter in a cell
This is a gas flow coupled with DPM problem. The Micro only have c, t as variable but I need the particle diameter in a cell, how can I make a connection between them? Thank a lot!
March 1, 2006, 12:50 |
Re: Help with particle diameter in a cell
Look in UDF manual for particle properties.
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
Iclude particle diameter effect in wall? | yueroo | FLUENT | 0 | April 14, 2001 03:56 |
