GAMBIT mesh please help me
Old   February 27, 2006, 08:11
Default GAMBIT mesh please help me
naus
Hello, I have rectangulaire room with a table, I want to mesh the volume without table,
I have create the volume of the room V1 then I have create the volume of the room V2 then V3=V1-V2,
I mesh V3 with tet hydrid,but when I want to export it I found ERROR : An incorrect mesh has been store... although my mesh has successfully done.
Where is the probleme ?
please helpe me.
Old   February 27, 2006, 08:38
Default Re: GAMBIT mesh please help me
mAx
take care that your v2 isn't still in your geometry. In the substract boolean operation, you have the possibility to retain (or not) the object with which you will substract. In other words look at you whole geometry, by shading it. YOu should have only one volume
Old   February 27, 2006, 14:10
naus
HI mAx, thank you for your help,I will do what you had suggest to me.
now please, in bondary condition (always with GAMBIT) must I declare table's surfaces(as they belong to V3) like interface???? knowing that I have declared all the walls,the inlet and the outlet diffuser(I have a ventiled room).
I'm new in GAMBIT/FLUENT please enlighten me.
naus
Old   February 28, 2006, 01:35
mAx
It depends on what you will calculate. But anyway you can define the table sufaces as wall (but rename them with a special name, for distinguish them with default walls) After that you always can change the Boundary Conditions in Fluent. Important in Gambit ist that you distinguish your surfaces. Hope it helps
Old   February 28, 2006, 05:49
naus
I will calculate the aeraulic flow around the table,
it is just to define all table surface's (at the same time) as interface in GAMBIT??
Old   February 28, 2006, 06:07
mAx
you can group the faces from the table as one entity. Then in Fluent you can compute what you want on this entity. explain why do you want to define your table as interface? Do you have conduction?
Old   February 28, 2006, 06:47
naus
I define my table as interface beacause I have not data about it.and in BC (FLUENT)there is not data to define with this type. it is right?
Old   February 28, 2006, 07:07
mAx
if you only will to compute the force generated by the flow on the table, you have to set your table as wall
Old   February 28, 2006, 08:51
naus
I set it as wall,you have right. When I export to FLUENT, I found this message of error: Error: access: unbound variable Error Object: phase-domain? it's a serious probleme??
Old   February 28, 2006, 09:58
mAx
phase-domain? are you working with multiphase?
Old   February 28, 2006, 10:01
  #11
matt
if u do the tutorials here http://unix.eng.ua.edu/Fluent.Inc/tg...guide/tg03.htm
u will not have any problems with your case...
Old   February 28, 2006, 10:18
  #12
naus
no I work only with the humid air in my conditionned room.
Old   February 28, 2006, 10:36
  #13
mAx
ok I got it. You certainly have one or more boundary name with a blank. for instance: WALL RED should be WALL_RED
Old   February 28, 2006, 13:00
  #14
naus
thanks matt for tutorials.
Old   March 1, 2006, 04:44
  #15
naus
thanks a lot mAx you are right, can you lighten me in FLUENT too! I will use in addition to model of energy the model of species because I would to display RELATIVE HUMIDITY and with this model I can, I have read it in chapiter 13 section 4, but I can't understand well how to do with mixture of dry air and h2o vapour(my fluid of interio is humid air).
Old   March 1, 2006, 05:40
  #16
mAx
i would advice you to do the tutorial about multiphase
Old   March 2, 2006, 02:32
  #17
naus
j'ai du mal à m'exprimé en anglais!!
bj,comment je peus choisir les bonnes BC appropriée a mon cas, sachant que je suis en 3D avec un écoulement turb modele k-e, j'ai utilisé en plus de l'équation de l'énergie, le modele"specises",j'ai la convection naturelle dominante. merci.
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Successive Mesh in Gambit ashish FLUENT 0 April 28, 2006 00:42
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
[Commercial meshers] Mesh import from gambit Kaushik Balakrishnan (Balakrishnan) OpenFOAM Meshing & Mesh Conversion 5 April 21, 2005 13:42
