FLUE GAS TEMPERTURE IS HIGH
Old   March 4, 2006, 07:12
Default FLUE GAS TEMPERTURE IS HIGH
MANOJKUMAR
Hello every body I doing the problem on combustion chamber. but the temperature is so high 1688k which is so high but in actual it come 800k. how to reduce that temp. MANOJKUMAR
Old   March 5, 2006, 16:34
Default Re: FLUE GAS TEMPERTURE IS HIGH
kafka33
Considering all the details provided, it looks like your model walls are adiabatic whereas the actual walls are not.
Old   March 7, 2006, 02:13
kiran kumar
after giving temperature bc to the wall ,switch on the radiation so that your temperature prediction is accurate.
Old   March 8, 2006, 00:32
MANOJKUMAR
Thanks The wall is addiabatic so there is no heat transfer.
And I also given the Radiation P-1 model if any more deatiled required then mail me at ms_project05@rediffmail.com MANOJKUMAR
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
condensation flue gas Marc FLUENT 0 November 30, 2006 11:44
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
