Hot jet
Old   March 12, 2006, 09:39
Default Hot jet
Mahdi
hello.., I am trying to model a hot subsonic jet (M_J=0.75 T_J=600K, A2/A1=0.31), nozzle is very simple one, and was working properly for cold jet. The problem I have already faced is that it diverges after some iterations! I have put pressure inlet BC for jet inlet, and Pressure outlet for sorrounding meduim. I suspect the magnitude of stagnation and supersonic pressure defined for BC of inlet and outlet pressure. Could someone give me a hand and tell me what could be the problem? as I said I worked with this geometry once for a cold jet and got good results (the only difference was that, I used velocity inlet for jet inlet as the flow was cold). THANKS Mahdi
Free water jet impinging hot solid surface, including boiling hamdy Fluent UDF and Scheme Programming 5 August 19, 2012 19:52
hot free jet : which parameters? Maxime_G Main CFD Forum 0 July 27, 2011 05:35
Jet in Hot Coflow by FireFoam Cristiano OpenFOAM 2 June 18, 2010 09:56
Multi-Species Jet tonyhamshaw FLUENT 4 August 8, 2009 05:45
Water jet in confined hot air cross flow Jim Clancy FLUENT 0 November 24, 2007 16:14
