March 9, 2006, 03:16 |
About convergence
I tried to run the same case file in single and double precision solver. The convergence limit is 1E-5. The double precision converges while the single one does not. Why this is so?
March 9, 2006, 12:19 |
Re: About convergence
Numeric diffussion.
March 9, 2006, 23:59 |
Then how can I avoid this? Thanks.
March 10, 2006, 12:36 |
Using the double precision solver obviously works. If you are using second order upwind try switching to first order, which is less susceptible to numeric diffusion.
March 10, 2006, 23:19 |
I'm using QUICK scheme now. I will try 1st order upwind. Thank you!
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 14:20 |
