Supersonic-Speed-Calculation
how can I start a calculation with a supersonic-velocity-inlet. There are problems with the pressure outlet. It's right to use a pressure-outlet or do I need another outlet definition. thanks cheers Gernot |
Re: Supersonic-Speed-Calculation
You should not use velocity inlet. Instead you can use pressure inlet or mass flow inlet. |
