UDF works in 2D but not in 3D? Suggestions?
I have a simple UDF to simulate sloshing of a tank. It works in 2D but not 3D. Anyone know why? I can't seem to find any documentation on 3D and UDF's. The UDF is below as a source term that I use in the BC's to the momentum eqn.
#include "udf.h" #define period 1.689 #define amplitude 0.005 DEFINE_SOURCE(cell_x_source, cell, thread, dS, eqn) { real source; source =(-1.0*amplitude)*pow((2.0*M_PI/period),2.0)*C_R(cell,thread)*sin((2.0*M_PI/period)*CURRENT_TIME); dS[eqn] = 0.0; return source; } |
Re: UDF works in 2D but not in 3D? Suggestions?
M_PI and CURRENT_TIME seem to not have been defined.... I assume you did it in your code....so ?
what do you mean by not working ? no compilling or not converging calculation ? |
M_PI and CURRENT_TIME don't need to be defined. These are internal to the code. I use this as an interpreted UDF in 2D and it works (interprets, runs, etc...) fine. However, once I go to 3D the code crashes. It still interprets but I get an ACCESS_VIOLATION error when I try to run it.
try to compile it, see if it is ok ? do you have an define adjust in your code ?
I don't have a c-compiler yet which is why I've been using the interpreted version. That shouldn't make a difference, should it? Also, I don't have a define adjust in my code. The only thing I do is use the UDF as a source term for the x-momentum equation.
I suggest to start calculation without your udf, for some time steps...then activate the udf..and see if it works...
I've tried that already too. :)
So without UDF the calculation work without bugs....mhh...
Try with replacing M_PI and CURRENT_TIME with constant numbers.... |
