March 13, 2006, 12:57 |
residuals oscillation
modeling turbulent flows, what can I do if residuals oscillate about a constat value far from convergence? Thanks |
March 13, 2006, 13:21 |
Re: residuals oscillation
switch on unsteady solver
March 13, 2006, 18:40 |
Im modelling turbulent flow with the k-e model. So far ive been using the steady flow solver.
Turbulent flow is always changing with time, so should you use an Unsteady solver for ALL turbulent flow modelling? Matt |
March 14, 2006, 05:13 |
If you're modeling external flows (flow around buildings, cars, airplanes), consider to extend your domain past the obstacles until the flow is fully developed. This hint can be applied also to internal flows, anyway...
Obviously, all remains valid if there are not other concerns, for example if there are not highly time dependant phenomena (vortexing) and you are forcing a steady solution... Hope this helps Edi. |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
what to monitor besides residuals? | franzdrs | FLUENT | 5 | March 21, 2013 03:59 |
Mesh size and solver residuals... | Scott | CFX | 5 | December 15, 2008 17:10 |
Oscillation of residuals in DPM (Ergent need!) | yooceframandi | FLUENT | 1 | February 28, 2006 06:46 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
