residual oscillation
Old   March 13, 2006, 11:36
Default residual oscillation
philippe
Hello, I am studying enclosed convection in small cavity and I want to evaluate the influence of gas pressure on thermal plume developped by a heated wire at the bottom of the cavity. Under 5 bar results fit well with experience, but for higher pressure, residual values of continuity start to oscillate. Perhaps somebody could help me ? Thank you. Philippe
Old   March 13, 2006, 13:22
Default Re: residual oscillation
mAx
switch on unsteady solver
Old   March 14, 2006, 03:04
philippe
Ok, but do I use small time step (and it will take a long time) or a large step ? Thank you. Philippe
Old   March 14, 2006, 03:32
mAx
if you ust to large time step, it won't converge. you must compute by hand the time step you need. for instance t=(minimum cell size of your domain)/(maximum velocity you are guessing) I would use adaptive time stepping
Old   March 14, 2006, 03:38
philippe
I am just trying adaptative time step, thank you very much for your answer. Philippe
Old   March 14, 2006, 03:40
mAx
de rien
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
