inverse poisson solver
Old   March 19, 2006, 11:26
Default inverse poisson solver
yamini
hi all ! i need to find the solution to an electrical field problem: potential field V(x,y,z) follows poisson's equation in a cubical volume conductor of varying conductivity mhu(x,y,z) in space. ie , â–¼²(mhu*V) = 0 There are many softwares that solve the forward problem: given conductivity of material(mhu), the potential field distribution is found for given current field. However, i need an inverse solver, ie: given the field(V) at certain discrete sparse points on the boundary for given current field, find the conductivity distribution (assumed piecewise constant function) in the material. Is this possible using Fluent and how? (say using Finite difference method) Kindly explain in detail as I am a beginner with respect to Fluent and how I should go about learning to code.
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 11:00
solver for Poisson eqn billboard Main CFD Forum 3 May 22, 2002 00:07
Mashing Problem? ji CFX 2 April 4, 2002 05:03
IMSL Poisson Solver FPS2H G. Wilson Main CFD Forum 0 February 19, 2002 12:22
Stretch Grid Poisson Solver G. Wilson Main CFD Forum 0 February 19, 2002 12:16
