Propagate Algorithms
Old   March 24, 2006, 04:32
Default Propagate Algorithms
Cyril
Hello, I'm trying to simulate a supersonic shell at Mach 2.4 (7.62mm, 20mm, 30mm, etc shells) and its sonic boom, 1 meter away (1 meter for the tests but it should be 8 meters minimum !!).
I've heard that the best method wasn't to simulate from the near to the far field directly but to procede in 2 steps (or 2 zones) consisting of the near field CFD solution and a propagation to the ground (from the near to the far field).
Does any body knows if this can be done with fluent ? (and where does end the near field...)
Thanks !
Cyril
CFD Lecture Course Numerical Solution Algorithms for Compressible Flows hjasak OpenFOAM 2 March 8, 2017 14:30
Algorithms (McGraw 2006) Please help itoa FLUENT 4 June 11, 2009 00:10
Why SIMPLE family algorithms are not used in LES? Linfeng BI Main CFD Forum 5 November 19, 2002 19:05
AI Algorithms? Radu Bondar Main CFD Forum 0 October 7, 2002 18:13
steady k-eps algorithms Bengham Main CFD Forum 0 February 5, 2002 09:34
