modeling thermal resistance in Fluent?
Old   August 28, 2010, 09:28
Default modeling thermal resistance in Fluent?
gholamghar is on a distinguished road
Hello
I am modeling a pin fin heatsink with gambit and fluent,is there any way that i can model the thermal resistance between the fins and the base plate of the heatsink? because my heatsink is not made from methods like cold forge,first the base plate is drilled so that some holes are made in the base plate and then the fins are pressed into the holes and because of this there is a thermal resistance between the base plate and fins.any help would be of great appreciations.
Regards
gholamghar is offline   Reply With Quote
Old   August 28, 2010, 12:07
xrs333
xrs333 is on a distinguished road
you can use the so-called thin-wall resistance model, which is set in the wall boundary condition panel, for the modeling of the heat resistance between the surfaces of the fin and the hole in the plate. But the resistance itself must be known.
xrs333 is offline   Reply With Quote
Multiphase flow modeling: CFX or FLUENT? Paul Main CFD Forum 8 January 24, 2012 09:25
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
Contact modeling in FLUENT pchama1 ANSYS 3 May 27, 2011 16:34
Is FLUENT capable of Modeling Breaking Waves Justin FLUENT 0 June 29, 2009 00:03
Modeling Hydrodynamics in Estuaries using FLUENT SUMAN KHAMRAI FLUENT 1 December 23, 2005 16:55
