Autocad for gambit
Old   April 30, 2006, 03:08
Default Autocad for gambit
asghari
Hello Dears, I am a Gambit user, I want to know ,Can i make my geometry in Autocad and then i transfer to gambit ?
Old   April 30, 2006, 05:31
Default Re: Autocad for gambit
ravindra bankar
yes , you have to save file as .sat and call in gabit import use first option and you will able to get your gometry in gambit. also you can import as parasolid , igs, and mainy from . have good luck . help other if you learn fluent . by ravindra
Old   April 30, 2006, 15:14
philipov
Look for an old topic.There was the same question. Definately use *.sat format. Correct the geometry (clean-up) later in GAMBIT if needed.
[Other] Import autocad into Design modeller lcea ANSYS Meshing & Geometry 1 December 1, 2010 13:15
Import autocad into Design modeller lcea CFX 0 November 30, 2010 04:13
AutoCAD file import enGrid / Netgen deniggo OpenFOAM 1 August 4, 2010 09:38
Civil Engineers and AutoCAD H Main CFD Forum 0 February 26, 2009 18:07
Meshing AutoCAD geometries using ICEM Yuqing CFX 2 November 16, 2006 20:08
