Autocad for gambit
Hello Dears, I am a Gambit user, I want to know ,Can i make my geometry in Autocad and then i transfer to gambit ?
Re: Autocad for gambit
yes , you have to save file as .sat and call in gabit import use first option and you will able to get your gometry in gambit. also you can import as parasolid , igs, and mainy from . have good luck . help other if you learn fluent . by ravindra
Look for an old topic.There was the same question. Definately use *.sat format. Correct the geometry (clean-up) later in GAMBIT if needed.
