Urinal Problem
Old   May 5, 2006, 07:20
Default Urinal Problem
Adam Jackson
I am currently trying to model a stream of urine splashing off the inside surface of a urinal in 2d. Does anyone know how to model a jet of water hitting a surface and splashing back off the surface under gavitaional and atmospheric forces?
Any help would be much appriciated.
Cheers
Adam
Old   May 5, 2006, 09:59
Default Re: Urinal Problem
mehmet
I believe u need to do VOF analysis for the break up...
Old   May 5, 2006, 10:05
adamjackson
Could you describe what you mean in more detail. and how do I setup my container that the experiment is contained within to have air at atmospheric pressure in it?
Old   May 5, 2006, 10:19
mehmet
i have not done VOF study yet, however u should focus on the break up section which is quite complicated. u should know the inlet velocity profile of urine to ur control volume. U can safely assume stagnant atmosferic conditions in a bathroom, also u can ignore mass and energy transfer between urine and air, and that should simplify ur case a bit. good luck
Old   May 5, 2006, 11:02
Aireen
I would suggest you read the tutorial regarding the ink jet coming out from the nozzle. Then you could adjust the problem accordingly. To get this tutorial online, log on Fluentusers.com
Old   May 5, 2006, 11:17
adamjackson1606
Where do you find that? If it is not online could you possibly email it to me at: adamjackson1606@aol.com
I am not registered for the fluent website as I am using the program at my university.
Thanks for you help
Old   May 5, 2006, 12:34
Benzamia
CAn u send me the geometry of your probleme i think that i can help u, you ll work withe the VOF methode
Old   May 5, 2006, 13:09
Father Jack
Drink 12 pints of Guinness, go to your nearest wall and watch what happens. Nothing like real experimentation to satisfy your curiosity and see VOF in action.
Old   May 5, 2006, 15:30
philipov
Posted By: Father Jack Date: Fri, 5 May 2006, 11:09 a.m. In Response To: Urinal Problem (Adam Jackson)
That is GOOOOOD!!!!!! )))))))
Old   May 5, 2006, 16:58
Margret Wee-lliams @littlebritain.com
Why don't you also use FSI for constipation ?
Old   May 5, 2006, 18:17
  #11
Peter
lol
Old   May 10, 2006, 10:30
  #12
cfd
If you'll pardon the pun, should be a piece of p*ss.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
