3D mesh around a wing using gambit
Old   May 15, 2006, 11:51
Default 3D mesh around a wing using gambit
M. ssuri
I am using Gambit for creating 3Dmesh round a wing , I need a help for creating this mesh . I tried to mesh edges, faces and then volumes. This method worked for volumes which does not contain wing. for the volume which contains wing this method fails...Why???!!!
Can any one send me a steps or advise?
Greast Thanks
Old   May 15, 2006, 13:55
Default Re: 3D mesh around a wing using gambit
anindya
There is a gambit tutorial for meshing an airplane geometry (half section). Maybe that will help you.
Old   May 16, 2006, 02:06
dongtao
where is the tutorial file?In the standard gambit help file, I cann't find any tutorial file about meshing an airplane. could you sent this file to my email:dongtaomail@gmail.com, thanks in advance.
Old   May 16, 2006, 13:44
Anindya
Find the tutorial guide here.
http://www.wka.tu-harburg.de/intra/d...df/tg/tg14.pdf
Anindya
Old   May 17, 2006, 11:42
M. ssuri
Thanks Anindya,,, This will help me
M. Essuri
Old   May 25, 2006, 02:44
QuynhGiao
you can use triangle to mesh all the face of volume.Note:divide many vertices on leading edge and trailing edge of the wing.then, you can use Tgrid to smooth the mesh.You can email to me ro have more info.I am going to graduate from Univesity and my thesis is "Flow over an 3D airfoil using gambit and fluent..""
Old   June 6, 2006, 10:38
QGiao
Dear aerosapce_iist@yahoo.com, I can't email to u. You can mesh your foil in gambit and then u use fluent, set the condition in fluent e.g. define model(solver,viscous,..).In gambit, u set the bounary condition for faces(velocity inlet, pressure outlet, symetry, ..) to set the value of boundary condition to solve...The residual u use in Fluent is about 1e-5. after about 2500 iteration, the solution converges anh u will have the pressure.I send u apic of wing that I have done.hope that I will help u.
Old   June 6, 2006, 10:39
Default aerosapce_iist *NM*
QGiao
Old   April 30, 2009, 14:05
Kartik
kartikkp is on a distinguished road
Originally Posted by QuynhGiao
;132543
Hi
i would be glad to see you work. i am looking to work on same lines.
my email id is kkadakia2009@gmail.com
regards
kartik
kartikkp is offline   Reply With Quote
Old   April 30, 2009, 15:06
Smile Hii
ANIL
makaero is on a distinguished road
@@: QuynhGiao
I am working on" Flow over 3d wing with sinusoidal leading edge", but i coudnt get a good volume mesh in Gambit because of sharp trailing edge...
In next attemp, i joined the last two points of airfoil with straight line, but the 3d Boundary layer resulted in highly skewed elements.
I wud be glad to see your work, it might help me...looking forward to hear from you.
email: anilsmailaero@gmail.com
Thank you.
makaero is offline   Reply With Quote
Old   July 21, 2010, 02:04
nvtrieu is on a distinguished road
Hello Quynh Giao,
Today, I've just found your post here. It was posted over 4 years ago. However I hope you still work with CFD now! ^_^. Therefore, I would ask your email to discuss with you about this topic.
Thanks you so much!
Nguyen Van Trieu.
Email: trieuckgt@gmail.com
nvtrieu is offline   Reply With Quote
Old   February 9, 2012, 16:49
Amr Ahmed Ahmed El feky
mero_magiver is on a distinguished road
Sorry i have the same problem . I am using Gambit for creating 3Dmesh round a wing , I need a help for creating this mesh . I tried to mesh edges, faces and then volumes. This method worked for volumes which does not contain wing. for the volume which contains wing this method fails..
The link of tutorial
http://www.wka.tu-harburg.de/intra/d...............is not working
mero_magiver is offline   Reply With Quote
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 06:28
[ICEM] Structured Mesh 3D Wing Tip Michiel ANSYS Meshing & Geometry 5 October 21, 2010 08:39
Mesh Resolution in Gambit Vidya Raja FLUENT 2 January 18, 2006 23:35
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
