May 15, 2006, 10:14 |
cold-flow??
hello ! Please how modeling cold flow in liquid fuel and air(C5H12-Air), how to tell to fluent there is no flame ???
May 15, 2006, 10:33 |
Re: cold-flow??
Hi
You can switch off the volumetric reaction in the species reactions panel, and you'll have to switch off the species calculation in the solution controls panel as well. Steve |
May 16, 2006, 04:49 |
Re: cold-flow??
ok but how about species transport panel ??? should I define only the reactants as species ???( CH4,N2,O2) ???
thanks |
May 16, 2006, 05:17 |
Re: cold-flow??
Hello
I'm not really sure exactly what you mean by define 'only' the reactants as species. If you're using the species transport model then your reactants and products are defined as species. Steve |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
