pulsating static pressure around zero at pipe flow
Old   May 16, 2006, 13:47
Default pulsating static pressure around zero at pipe flow
David Kim
Hi, I am simulating the unsteady pulsating pipe flow by segregate solver. Very low Re, incompressible, inlet vel=0.1 + 0.04*sin(80pi * t) [m/s], pressure outlet (gauge press=0), PISO, working fluid air (constant density), operating pressure 101325 Pa, pipe dia 0.04m, length 0.2m.
I think this is very simple problem. But the STATIC pressure results along pipe centerline are unreasonable. I expected the results as the static pressure at inlet is larger than that of outlet. And the static pressure at inlet has a phase difference with that at different locations along pipe centerline, as well as with velocity profile. But there are no phase differences, and the static pressures fluctuate sinusoidally around 0 Pa at all centerline positions, that is, the static pressure has MINUS sign, and the static press of inlet is smaller than that of outlet (0Pa). This is very low Mach number flow. Should I use coupled implicit solver and ideal gas law to see the phase change? Any help is highly appreciated, David
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 15:13
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
Guessing the static pressure needed to produce flow rate jpo FLUENT 0 June 22, 2009 12:53
Pressure Drop - Please Help - Simple Pipe Flow Joe A. FLUENT 2 April 23, 2007 07:50
static pressure from mass flow rate SAM Main CFD Forum 4 October 27, 2004 13:15
