POROUS MEDIA PARAMETERS! Please Help!
Old   May 25, 2006, 06:16
Default POROUS MEDIA PARAMETERS! Please Help!
Jordi
Hi, I'm Jordi.
I am modeling a radiator wing with fluent. The wing has a little holes in the shape. Ok, I am using the porous media to modelize this wing. The problem is a don't know exactly what is the meaning of all the parameters in porous media. Next, I write down the parameters which I am interested. - Viscous resistance (1/Alpha) - Inertial Resistance (I think that it is the C2) - Power Law Model (C0 & C1) - Fluid Porosity (I think this one is the Gamma).
Ok, I was wondering if somebody could tell me what is the meaning of each one and which range of values take each one.
THANKS in advance,
REGARDS & PEACE,
JORDI
Old   May 25, 2006, 06:29
Default Re: POROUS MEDIA PARAMETERS! Please Help!
RM
I think porous media is for packed beds which i guess is nnot your case. I suggest you shd model your wing as a porous-jump type. In any case, the input parameters for porous media are described in detail in the documentation help files. If you cannot locate them, get back to me. However, i feel your case shd be modelled as a porous jump as in seives.
Old   May 25, 2006, 10:37
Jordi
Thanks RM
Old   May 25, 2006, 15:50
PEM
This is the typical question you should ask fluent support for advice, they are real experts in flow into porous medium as fluent is number one for this type modeling. They are really good. You would miss if you don't.
PEM
Old   May 26, 2006, 05:20
Jordi
I tried what you said, but the thing is It doesn't work like I want. If you know some other solution, please let me know! I will be so grateful, thanks
THANKS to everybody & PEACE!
JORDI
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
Permeability to porous media parameters Night FLUENT 2 June 28, 2006 02:19
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
