May 29, 2006, 01:09 |
exporting heat-flux data
I trying to find a Txt command to obtain total heat-flux of my an numerical case. I know that there is the possibility of using " file > export > custom-heat-flux ". but, i can't import file of the custom-heat-flux to TECPLOT Software to post-processing. How to save the format of exported file from FLUENT using "Txt Command" What Kind of format is reasonable for TECPLOT? Could anyone help me,please? Thank you very much, Kyoung-Ho |
Wall Heat Flux & Temperature | Greg Perkins | FLUENT | 10 | November 20, 2015 09:32 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Need Help on Heat Flux Profile within Pipe Wall | mep10jl | FLUENT | 3 | June 6, 2011 17:08 |
how to impose experimental dat as boundary conditi | Rogerio Fernandes Brito | FLUENT | 14 | November 25, 2008 05:47 |
heat flux to heat rejection | azmir | Siemens | 0 | June 23, 2004 20:53 |
