Error when loading a shared library
Old   May 27, 2006, 17:04
Default Error when loading a shared library
rid
Hi I got some problems loading a parallel udf. When I try to compile the udf, averything works well, but , when I load it I got this error therfore i can't open my old file case and dat
oapening library "libudf"... Primitive Error at Node 1: open_udf_library: No such file or directory
Library "libudf/lnx86/3ddp_host/libudf.so" opened
inlet_x_velocity
***************** thank you for your help
Old   May 27, 2006, 19:39
Default Re: Error when loading a shared library
Peter
If you used a fluent parallel session such as 'fluent 3ddp -t2' to build your UDF before (when you used the old case and dat files), then you will also need to start a parallel session now, before reading your case and data files.
Old   May 29, 2006, 11:57
rid
Hi, i used a fluent parallel session fluent 3ddp, i build my udf before reading my case and data files.the Udf is build with success. but when i read case and data file tje same error appears:
Opening library "libudf"... Primitive Error at Node 0: open_udf_library: No such file or directory
Library "libudf/lnx86/3ddp_host/libudf.so" opened please help me
Old   May 29, 2006, 13:47
Mac
Are the two machines of the same architecture (i.e. both are 32 bit or 64 bit)?
Old   May 29, 2006, 14:51
rid
i used a machine with 32 bits
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
BEGINNER: error while loading shared libraries ka1184 OpenFOAM 3 February 19, 2010 07:11
error while loading shared libraries: libelf.so.0: cannot open shared object file: No esmailpour OpenFOAM 7 October 15, 2009 07:09
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
