May 29, 2006, 08:44 |
display vectors in any time
i have simulate the flow of air in unsteady .
i want to display vectors at 5s,10s,15s,........... how to do this. olga |
May 29, 2006, 09:31 |
Re: display vectors in any time
You can do this over the Execute Comands ( solve/execute comands ). As there are a lot of settings you can choose I would recomend to do it the following way : Built up your picture with the vectors as you want to get it later ( maybe save this view - itīs helpful ). Go into the TUI and start with : display vectors now follow the path fluent gives you and write down your decisions on a sheet of paper. At last your picture should be rebuilt. After that write your comands as you have written them down into an execute command line ( If you do that a few times youīll see that you can shorten the commands for example dis for display ). Donīt forget to change from `iteration īto `timestepīin the pannel under WHEN. I hope that helps.
May 29, 2006, 15:31 |
i don't understand how to display vectors at 5s,10s,15s,........... how to do this. olga |
May 30, 2006, 03:09 |
1.) Open execute command-pannel ( solve/execute comands... ) 2.) Define comands : change from 0 to 1 3.) Change Iteration to Timestep 4.) In the textfield under `comandī write :
Dis vect vel vel-mag This is just for example. If you have opened a window with a picture of the vectorsettings you want to have, fluent will make a vectorplot after every calculated timestep. If you want to have that done just every 5,10,15sec increase the number in the execute comand pannel depanding on your timestep. |
Display Modes | |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 23:50 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 10:15 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
