How can the water cut be Set into a pipe flow‎
Old   June 1, 2006, 06:49
Default How can the water cut be Set into a pipe flow‎
B Saleem
Hi Fluent users:‎ I have two phase (oil-water) flow into a pipe , water flow in the button of the pipe ‎and oil in the top. I have a problem to enter the amount of water cut in the pipe ‎which it (25%) , anyone kindly tell me how can I did that?‎ Thanks ‎ Khalid ‎
Old   June 1, 2006, 08:21
Default Re: How can the water cut be Set into a pipe flowâ
HVN
You could use a patch
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
gambit code fluent on water pipe acai007 FLUENT 0 August 29, 2010 21:53
How to set the water cut KBS FLUENT 1 June 8, 2006 05:42
How I set the water height by given water cut KB Saleem FLUENT 0 June 4, 2006 03:48
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
