November 17, 2016, 14:27 |
prism layer or not?!
SinaJ
Rep Power: 16 |
I'm trying to simulate the water flow in a huge tank (diameter: 20m) with an inlet of 5m*5m (of course turbulence!) . So should I even consider prism layer for such a flow? I'm ok with having prism layers, but I realized that it makes the convergence much worse (specially in multiphase with mixture model). PS: considering that the boundary layer for such a flow would be something around 10cm, or even less. Thanks |
November 18, 2016, 16:16 |
Lucky
Rep Power: 65 |
If you have a no-slip boundary condition, then I highly recommend it. If however you have a slip condition, then no.
The biggest thing about prism layers is that wall adjacent cells are parallel to the wall and this helps prevent really stupid things from happening (like velocity vectors that go into the wall). Convergence problems with prism layers is most likely mesh quality issue. Automated meshers tend to have difficulty with prism layer generation. But you have no excuse for going into a simulation with a bad mesh, unless your geometry is really really complicated! If you want good results, make a nice mesh. |
November 18, 2016, 16:32 |
#3 | |
SinaJ
Rep Power: 16 |
BTW, let me explain how I mesh, maybe you could kindly recommend a better way: using ICEM, tetrahedral everywhere. One layer of prism layer with thickness of ~15cm. Splitting that single layer to 12 layers with size ratio of 1.1 or 1.2 PS: Unfortunately I'm not allowed to share the geometry. |
November 21, 2016, 08:09 |
Kushal Puri
Rep Power: 12 |
Y+ = 30 m good, can proceed with standard k-epsilon turbulence model
Prism Layer (Boundary Layer) Thickness | Peter-27 | STAR-CCM+ | 12 | March 27, 2022 12:25 |
Questions about Polyhedral and Prism layer meshing | niablis | STAR-CCM+ | 3 | September 23, 2016 00:32 |
[ICEM] Holes in the prism layer | Airon | ANSYS Meshing & Geometry | 3 | September 12, 2013 06:08 |
Trimmer & prism layer | peresah | STAR-CCM+ | 6 | October 6, 2009 14:39 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
