June 6, 2006, 06:49 |
problem with running UDF in batch mode
Hi All,
I am having problems with running my job in batch mode when i hook a udf to Fluent. Is there a way around this? What i have done is to use the compiled option to build the udf library and at the inlet and out of my boundary, i am using a udf. I am able to run it when i run fluent interactively. When i submit to the cluster, i get the following error message: Opening library "libudf"... Primitive Error at Node 0: open_udf_library: No such file or directory error: executing task of job 783222 failed: error: executing task of job 783222 failed: error: executing task of job 783222 failed: error: executing task of job 783222 failed: Is there anything i can do to have this job run in batch mode? My job is suppose to run on two processors and so i suspect i need to parallelize my udf? or i have to do something about the read/write commands in my job file? Any suggestions on how to fix this problem will be appreciated. Thanks in advance. James |
problem using property udfs in parallel mode | EllenW | FLUENT | 0 | June 23, 2009 17:18 |
UDF compiling problem in Flient 6.3 | jeevan kumar | FLUENT | 2 | February 25, 2009 00:43 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
fluent stops batch mode on error | Ralf Schmidt | FLUENT | 1 | March 1, 2008 10:35 |
UDF hook problem in command line mode. | Benlong | FLUENT | 1 | November 12, 2007 14:45 |
