Good MEsh and a bad one
Old   June 3, 2006, 14:16
Default Good MEsh and a bad one
Himanshu Sharma
hi all , can you pls give me some suggestion or link to a website which describes the difference b/w a good mesh and a bad one. pls help its urgent....
Old   June 3, 2006, 15:36
Default Re: Good MEsh and a bad one
Himanshu Sharma
is the mesh in the following link good enought o solve for the flow
www.home.iitk.ac.in/~himan
regards Himanshu
Old   June 6, 2006, 02:35
Claud
Hi Himanshu, in GAMBIT you can check your mesh for the worst element. It should be not too close to 1 (0.6 or below should be perfect). Furthermore, the cells should be longer than wide (in flow direction). Unfortunatelly, I couldnt check your mesh. Claud
Old   June 6, 2006, 03:24
san
select the quality check button ->
check the element type 2D/3D -> go for Range option ->
then go for skewness check.
you can easily see the mesh values for each mesh volume.
i hope this will help you.
bye san
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
good mesh RKT Main CFD Forum 1 October 25, 2008 03:50
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
