how to display contours in unsteady..........
Old   June 5, 2006, 16:26
Default how to display contours in unsteady..........
sandra
i have simulate the flow of air in unsteady case , i want to display my contours or vectors every time(5 seconde,10....) give me the procedure step by step please
thanks in advance
Old   June 5, 2006, 18:14
Default Re: how to display contours in unsteady..........
HAR
What I have done is to set up the animation options before interating in order to save every time step you want. Solve=>Animation=>Define..., After the simulation, you can watch the animation every time step you selected. It should work.
Old   June 6, 2006, 03:10
san
i wanted to know how to carry out unsteady case in fluent. i have two fluids flowing through concentric tubes.
outer fluid is cold fluid and inner fluid is hot fluid. inbetween we have solid wall.
flow is counter flow.
it will be very helpfull if you can give solution regarding this.
with regards san
Old   June 6, 2006, 07:31
sandra
i don't want work with animate
Old   June 6, 2006, 08:16
sandra
hi, har its very very easy ,can you specify your probleme
2D, Can't Display Filled Contours. David FLUENT 11 June 8, 2018 17:59
Display pathLines and contours together Chris FLUENT 1 November 29, 2006 05:34
display contours at any time urgent sandra FLUENT 0 June 1, 2006 08:59
display contours every time linda FLUENT 1 May 28, 2006 21:17
display contours every time sandra FLUENT 5 May 28, 2006 00:29
