June 4, 2006, 19:43 |
UDF COMPIL FOR FLUENT
hello evry body I have Fluent 6.12.16. I have installed Basic C compiler the probleme is for dynamic mesch when i use
define---user-define -fuction-interpreted they work for other udf (profile velocity) but not for motion gird he make me error : Warning: incorrect cg motion UDF benzamia on zone 3 (assuming no motion) can any one help me please it's very urgently for me ------------- programme----------------------- #include "udf.h" DEFINE_CG_MOTION(benzamia, dt, vel, omega, time, dtime) { /* reset velocities */ NV_S (vel, =, 0.0); NV_S (omega, =, 0.0); if (time<0.1) { vel[0] = 0; } else { /* set x-component of velocity */ vel[0] = 0.1; vel[1] = 0; } } |
June 5, 2006, 04:21 |
Re: UDF COMPIL FOR FLUENT
why don't compile that? regards
June 5, 2006, 16:23 |
can you help me i want to make move my cylinder in the middle of the fluid when download udf for dynamic mesh zone, fluent make me a warning: Warning: incorrect cg motion UDF mouvement on zone 4 (assuming no motion) zone 4 is my cylinder
what means this warning thanks |
June 8, 2006, 01:00 |
Hi Benzamia,
I got the same problem than you.In fact, with a DEFINE_CG_MOTION, you have to compile it and not interprete it (it doesn't work otherwise). Be sure than your C compiler works well otherwise you will get the same problem. I suggest you Microsoft Visual C++ 6.0 (the official version; the free version doesn't work for this). Your UDF is correct, you don't need to put vel[1]=0, it's done by NV_S(vel,=,0.0). Furthermore, I use an UDF quite similar to yours for a dynamic mesh but the mesh isn't updated and after a few iterations, I've got this message: Mesh Statistics: Min Volume =-6.89746e-002 Max Volume =5.99320e+004 Warning: negative cell volume detected! Error: Update dynamic mesh failed! Error Object: () whereas I specified a dynamic mesh!! Any idea?? |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
