June 9, 2006, 04:35 |
Saving particle (DPM) data to file?
Hi
I'm running a transient case with a discrete phase model. I find two ways to write particle data to a file. 1) The first alternative is to use "display/particle-tracks/current-position/write" to file. Then I get data for all particles in the domain. 2) The second alternative is to use "report/discrete-phase/sample/default-interior" Then, as far as I understand when I pick default-interior, I should also get the particle data for all particles in the domain. However, I will not get the same data in the two files. I get much less data in the second case, why is that? Does it save data in a different way? and do I really get all data when I chose default-interior? I need to use the second alternative in order to be able to save data continuously during computation, so its important to get it right. Regards Philip |
June 10, 2006, 06:54 |
Re: Saving particle (DPM) data to file?
I think is better to use a UDF to define your output format in case 2).
Try to have a look to UDF Manual or say as which are your particle tracking values. Regards. Adriano |
June 12, 2006, 01:41 |
Thanks Adriano I did write a UDF. But the thing is that, even if I write a UDF-output file I still only reach the particles in the specified surfaces which I pick, default-interior here, and I'm still not able to reach all particles in the domain.
If you or anyone else know how to reach all particles, it would be a great help for me. Philip |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 08:33 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
