June 14, 2006, 03:33 |
*****Particle Tracking In DPM
Hi users,
I've got a problem with my DPM model. I'd like to impose a UDF that describes the porous zone behavior during tracking particle routine. I'd like to stop certain particle (selected by their particle identification number). My problem is restarting particles tracking of part_id that are not in my interest!! I attach my code (semplified) Please and thank you. Adriano. DEFINE_DPM_BC(ADESIONE_SCAF,p,t,f,f_normal,dim) { /*confronto part_id corrente - part_id nell'array di randomizzazione*/ int select,i,l; FILE *fp; /*chiamata della funzione che fa il confronto */ select=confronta(p->part_id, a); //uscita if (select==1) { Message("select = %d part_id ferma =%d\n",select,p->part_id); fp=fopen("ADESIONE_SCAF.txt","a+"); /*scrivo nel file la posizione in cui si č fermata e in quale faccia*/ fprintf(fp,"((%10.6g %10.6g %10.6g %10d %10d %10.6g %10.6g %10.6g) %d)\n",p->state.pos[0],p->state.pos[1],p->state.pos[2],t,f,f_normal[0],f_normal[1],f_normal[2],p->part_id); fclose(fp); Trap_Particle(p); p->gvtp.n_trapped+=1; l=PATH_ABORT; /*attribuisco il 'trap' alla particella che č realizzato con la funzione*/ } if (select==0) { p->gvtp.n_escaped+=1; l=PATH_ACTIVE; } return (int) l; } |
DPM particle tracking in stirred tank | parisa- | FLUENT | 1 | August 7, 2012 12:03 |
Particle tracking in DPM | Harpreet | FLUENT | 0 | August 27, 2011 04:12 |
DPM particle tracking | parisa- | Main CFD Forum | 2 | June 15, 2011 05:12 |
Itīs possible to use this in unsteady dpm tracking? | JSoares | Fluent UDF and Scheme Programming | 3 | June 9, 2011 10:41 |
DPM tracking particle | Clementine | FLUENT | 0 | November 7, 2008 18:08 |
