June 21, 2006, 09:02 |
adapting mesh in FLUENT
Hi all
while running the FLUENT simluation i got a warning: "Turbulent Viscosity is limited to Viscosity ratio 1.0e+05 in 3 cells". Is there a possibility to identify these cells and adapt the mesh for these cells. I have been searching for this issue in the USER'S guide, but i didn't find a relevant information. Please let me know your ideas and advices thanks in advance |
June 22, 2006, 15:59 |
Re: adapting mesh in FLUENT
Go to Adapt --> Iso-Value --> Turbulence (from the drop-down menu) --> turb. viscosiy
There you can compute the min- and max-values and select a range. All cells satisfying this condition will be selected. |
[ICEM] Using Surface Mesh from ANSA for Fluent Sim | tommymoose | ANSYS Meshing & Geometry | 15 | March 3, 2016 17:29 |
[Commercial meshers] Cannot convert fluent or tgrid hexcore mesh | aerogt3 | OpenFOAM Meshing & Mesh Conversion | 2 | October 22, 2010 11:55 |
Can anybody tell me what does fluent do using MESH MOTION? | enry | FLUENT | 0 | October 6, 2010 12:54 |
Can Fluent handle a degenerate block? Error while reading mesh... | Anorky | FLUENT | 1 | May 1, 2010 12:47 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
