FLUENT Problem, please help
Old   July 29, 2006, 06:58
Default FLUENT Problem, please help
Melanie
Hello, for my studywork I simulate the flow through a centrifugal pump. I have four fluid-zones, 1 rotating, three static. During the Iteration, at first, all values seam to converge. When the errorvalue reaches about 0.009 it begins to increase again. Can somebody of you tell me what are possible reasons for that and what I can do now to solve the problem? Thank you... Melanie Kramp
Old   July 29, 2006, 22:17
Default Re: FLUENT Problem, please help
Le
Please check the models -> solver, choose the method which is suitable for your calculation. If state is unsteady, check the time step, grid size as well. If the time step or/and grid size are quite large, the solution will oscilate. Good luck,
Old   July 29, 2006, 23:24
thomas
Melanie, First of all, do 10 iterations and check your mass flux at the inlet is everything looks right. Then from time to time stop your calculation and check the contour of turbulence and velocity to see where you calculation is diverging, is it in a particular area of you domain or is it general. Let us know !
My first thought would be - did you scale your domain, i mean you may have done you mesh in gambit in "in" and leave in "meter" in your calculation. It could be also because of you MRF set-up. Good luck
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
Fluent problem Z FLUENT 1 April 8, 2005 04:22
