The residuals in FLUENT
Old   June 26, 2006, 15:34
Default The residuals in FLUENT
summer
Hello,everyone. I have a simple question about the residuals in FLuent. Are the resduals in FLUENT relative value or absolute value? I have finished a calculation with the residual of 10-4. When I continue the calculations, the residuals don't change any more. Is is a satisfied result? Need I change some parameters to get better result? Thanks!
Old   June 28, 2006, 09:09
Default Re: The residuals in FLUENT
Pratik Mehta
i think they are relative values , if u observe no change in the result of your residual then i think you should stop your iterations , but make sure u see these behaviour well below in negative directions like negative 5 or 6 or whatever u have set in th residual check
i hope i have answered you
cheers
Old   June 28, 2006, 10:31
summer
Thanks very much. Best wishes.
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
Fluent Parallel/Serial version..jump in residuals Sandeep Abhyankar FLUENT 4 January 10, 2000 10:57
