Value in a specific point
Old   June 30, 2006, 04:26
Default Value in a specific point
Armando
I have a tube. I want to measure the pressure in a section of the tube. I can use for this the Contours tool. But I want also to get the value in some specific points of the section and I don't know how.
The right mouse button with contours has not enough accuracy.
I have tried creating several "point surfaces", and using some kind of report there, but I am not sure about what option I should try.
Any help is appreciated.
Thank you,
Armando.
Old   June 30, 2006, 05:44
Default Re: Value in a specific point: Vertex or Facet??
Armando
Hi again,
I have been working on it. I think the best way is the one I was trying: - Create several "Point Surfaces" - Use the report: "Surface Integrals" - Select "Static Pressure"
But I don't know what kind of measurement must I choose there: Vertex average or Facet average??
(There is another post where this is discussed but I don't full understand it. I just want the static pressure in a point of the section)
Thanks.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
