solidification/melting model - moving boundary
Old   June 28, 2006, 07:20
Default solidification/melting model - moving boundary
Thomas Bauer
Hi, I have tried to set up a simple 1D moving boundary problem with a phase change material and track the phase front. We get agreement with the analytical solution for Fluent Ver. 6.2 but not for Ver. 6.1. The tutorial case file in Ver. 6.1 works fine but is too complicated for a start. Are there differences in the two Fluent versions for the solidification/melting model? Has somebody set up a simple 1D moving boundary problem in Ver. 6.1 successfully? Thomas
Old   June 30, 2006, 05:35
Default Re: solidification/melting model - moving boundary
Thomas Bauer
This was one example from the literature, which didn't work with Fluent Ver. 6.1:
Phase change material ice: Density d=1000 kg/m3 Specific heat Cp=4187 J/kgK Thermal conductivity k=0,564 W/mK Latent heat L=333400 J/kg Melting temperature Tm=273 K Initial temperature T0=272.95 K (solid)
Dimensions/mesh: 0.1 x 10 cm (Mesh 1x100)
Boundary conditions: Left wall: T = 298 K (25°C) Right wall: Heat flux = 0 W/m2 Bottom/top: symmetry
I calculated the phase front position analytically and the result is also given in the literature below:
The phase front should reach 1cm at 1301 sec.
Has somebody verified successfully an 1D melting problem in Fluent 6.1 with an analytical solution?
Thomas
Literature: Alexiades, V., Solomon, A.D. (1993) Mathematical modeling of melting and freezing processes, Hemisphere Pub., p. 40ff
Old   July 6, 2006, 01:42
Lim
Hi Thomas,
I'm having some problems in solidification/melting model too.
I have this glass sphere container containing PCM (initially solid), where hot water will be circulating around the outer surface of the sphere.
should VOF be used in this case? I need to see the phase change of the PCM. How do i go about...
Can u pls help...
Lim.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Turbulence model for CFX moving mesh songxguan CFX 7 June 28, 2009 21:05
