July 17, 2006, 04:18 |
Materials Problem
I get a message appearing when I select engine oil from the fluent database. It reads
Material engine-oil New property "Molecular Weight" has been added. Selecting constant method for "Molecular Weight" -- data required. I assume this means that I am required to specify the molecular weight of the oil, if this is the case where/how do i input this additional data. I am a novice in the use of Fluent and would appreciate help with this. Thank you in advance John |
July 17, 2006, 06:17 |
Re: Materials Problem
If you look in the >Define>Materials menu and select the fluid you've just copied from the database (engine oil) you'll see that fluent will have set a default value for molecular weight for you. Anytime you want to change material properties just change the value in the box - simple as that. The bit where fluent says 'data required' occurs everytime you copy a new material so it's not making a request in this case. Regards Steve |
Display Modes | |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Isolated walls in heat transfer problem | Maria | FLUENT | 1 | August 13, 2007 06:04 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
