July 19, 2006, 10:54 |
meshing 3 connected volumes with gambit
Hello dear colleages! I will greatly appreciate any help on meshing with Gambit.
I want to have a splitted and connected/bidierctional three volumes. The first volume (the Gas diffusion layer)is 45 X 45 X 0.2 units, the second (Bipolar plate) is 55 X 55 X 1 units, the third one (the flowfield) is 1 unit deepnes and 1 unit breith channel. This flowfield is inside the second volume. All are concentric and have contact. I cannot get to mesh the second volume with hexahedral cells. Just tetrahedral (wich are useless due to our limited PC capacity of 4 GB RAM) The failure i get when using hexahedral is a logical cube for meshing is not found. I have tried to mesh all edeges, faces and then volumes, but at the end, even when I have simetrically meshed all the faces, I donīt get the volume meshed. I will greatly appreciate any suggestions! Miguel |
July 20, 2006, 05:50 |
Re: meshing 3 connected volumes with gambit
Can you post a picture of your domain? A hardcopy with "connectivity option" turned on would be best to understand you problem better.
RoM |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 00:35 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
Meshing two volumes | Vidya Raja | FLUENT | 1 | October 5, 2005 02:46 |
GAMBIT crashes during meshing | Nick | FLUENT | 6 | October 28, 2004 03:02 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
