case about laminar flow past a surface-mounted rib |
August 8, 2006, 07:20 |
Hello,I am conducting a calculation using FAM(Finite Analytic Method),the calculated problem is laminar flow past a surface-mounted rib with Re=800, does anybody know about a benchmark solution of the mentioned problem using Fluent or other method? So I can make a comparison and check out my calculated results. Any help is appreciated. Thanks in advance! Sincerely, Liu
Flow over 2D Cylinder, Laminar and Turbulent | Tsr63 | FLUENT | 5 | November 13, 2014 12:13 |
Validation for laminar Disperse phase flow | shashwat | Main CFD Forum | 0 | April 4, 2008 02:20 |
Laminar flow or Turbulent flow | mech | FLUENT | 0 | January 27, 2007 18:51 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
complex geometery as a test case for laminar flow code | Morteza Marivani | Main CFD Forum | 1 | December 7, 1999 04:33 |
