July 24, 2006, 21:05 |
Set the boundary condition
Hello, everyone. Today I am suddenly confused about the setting of the boundary conditions in FLUENT. For example, I model two-phase flow and set the velocity inlet bounndary of the two phases. Initially, the void fraction of the secondary phase is 0.05. However, after I finish the calculation, I notice that the void fraction at the inletis is only about 0.002, which is much lower than that of the initial boundary condition. Is it reasonable? Why it does not agree with the boundary condition of the inlet? Does it indicate that if I require that the void fraction of the flow at the inlet is 0.05 in the end, I have to set the initial value much higher to face the final requirement? Thanks in advance.
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 06:49 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
how to set the porous boundary condition | chocheng | FLUENT | 2 | March 22, 2001 13:42 |
