strange divergence when solving multiphase problem
Old   July 27, 2006, 06:38
Default strange divergence when solving multiphase problem
tanghao
hi all! I am now struggling with a high-pressure gas-liquid multiphase problem. I found it strange than when the density of gas is set to constant, the solution can converge; while if i select IDEAL-GAS as it's density, the solution will diverge in one time step, and the pressure and temperature all exceed lower limits. I tried to adjust the lower limit to a reasonable number, but it seems didn't work!
Anyone could help me??
Old   July 27, 2006, 07:39
Default Re: strange divergence when solving multiphase pro
KP
Check with your URFS. Try to tighten them.
Old   July 27, 2006, 19:47
tanghao
Thanks for ur advice. you mean TIGHTEN them ? then which URF should be tightened?
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
