August 3, 2006, 04:16 |
Two Questions about FLUENT Skills
I'm a undergraduate student studying Fluent tutorial now. If you could give me a little help, it would be very grateful to me. ^^
There is a hexahedron chamber. It has three holes, two is small and one is larger. With these holes, make the chamber to be vacuummed. From atmospheric pressure to 5Pa, use two small holes, and to vacuum, use a larger hole. ๋ฌธ์ ๋", 5Pa ๊น์ง๋" ์'์ ๊ตฌ๋ฉ ๋ง์ ์ฌ์ฉํ์-ฌ ๊ธฐ์ฒด๋ฅผ ๋ฝ'์๋ด๊ณ , The problem here, if the pressure leads to 5Pa, FLUENT has to be stopped at that point, and switch the condition(from small holes to larger one) it should be reIterationed. So, I made every effort to find that menu in FLUENT, but I could not find any. Is Everyone know about that? It would be very thank you ... ๊ทธ ๋ค์๋ถํฐ๋" ํฐ ๊ตฌ๋ฉ ๋ง์ ์ฌ์ฉํ์-ฌ ์ง๊ณต์- ์ด๋ฅด๊ฒ ํ ๊ฒ์ธ๋ฐ์"~ FLUENT ๋ฉ"๋ด ์ค'์-์, ์ผ์ ์๋ ฅ(์-ฌ๊ธฐ์๋" 5Pa)๊น์ง ๋ค๋ค๋์ ๋, Stopํ๋" ๊ฒ์ด ์ด๋ค ๊ฒ์ด ์์๊น...ํ๋" ๊ฒ์ ๋๋ค. 5Pa์-์ ์คํ' ํ ๋ค์, ํฐ ๊ตฌ๋ฉ์ผ๋ก ์กฐ๊ฑด์ ๋ฐ"๊ฟ"์ Iteration ํด ์ฃผ์ด์ผ ํ๊ฑฐ๋" ์"~ ์ ๋ฐฐ๋๋"ค... ์กฐ์ธ ๋ถํ๋"๋ฆฝ๋๋ค. ^-------^ ์์ฐธ~ ํ ๊ฐ์ง ๋" ์-ฌ์*๊ณ ์... ์ฒด์ ์ ์๊ณ ์๋" ๋๊ธฐ์์ Chamber๋ด์ ์ ๋ ๊ตฌํ๋" ๋ฐฉ๋ฒ ์ข... ^^;; |
August 3, 2006, 04:22 |
Re: Two Questions about FLUENT Skills
I'm an undergraduate student studying Fluent tutorial now. If you could give me a little help, it would be very grateful to me. ^^
There is a hexahedron chamber. It has three holes, two is small and one is larger. With these holes, make the chamber to be vacuummed. From atmospheric pressure to 5Pa, use two small holes, and to vacuum, use a larger hole. The problem here, if the pressure leads to 5Pa, FLUENT has to be stopped at that point, and switch the condition(from small holes to larger one) it should be reIterationed. So, I made every effort to find that function in FLUENT, but I could not find any. Is Everyone know about that? It would be very thank you ... The other one is... The way(or equation) to measure a flux of the already known size of hexahedron. |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
CFD beginner:- Help needed, general questions on Free jets? (Fluent 5.2.3) | Wong, R.Y.T. | Main CFD Forum | 5 | October 22, 2010 00:51 |
solving ocean wave with Fluent or CFX? | gholamghar | Main CFD Forum | 1 | March 21, 2009 12:49 |
