Turbulence Models
Old   May 25, 2012, 03:35
Default Turbulence Models
Helen
oborona is on a distinguished road
Hello!
Can I use two turbulence models in the one domain?
oborona is offline   Reply With Quote
Old   May 25, 2012, 06:29
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
No. Not possible.
SST is combination of two models : K-Epsilon and K-omega, but only limited to core flow and boundary layer respectively.
Far is offline   Reply With Quote
Old   May 25, 2012, 06:47
Helen
Thanks. it is a pity. I can't use SST model to model flow with combustion.
Old   May 25, 2012, 07:02
Far
Sijal
However you can choose DES or DDES model. Also you can go for Embedded LES (E-LES)
Old   May 25, 2012, 23:39
François Grégoire
macfly is on a distinguished road
Why can't you use SST for combustion? I'm about to start my turbulent combustion modeling, I'm in the process of choosing my model. And if I start Fluent and I choose the k-w SST turbulence model, most of combustion models are still available (from a quick look).
I'm probably missing something... can you please to enlighten me?
macfly is offline   Reply With Quote
Old   May 28, 2012, 06:36
Helen
I think I was wrong. I have the out-dated information that combustion models need the epsilon-equation but not omega-equation. But as was found I can use SST model with combustion.
different zones, different turbulence models gmwsy FLUENT 5 June 17, 2020 15:42
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Tutorial 21: Turbulence models spatialtime CFX 4 April 24, 2009 05:25
Turbulence models for GCV method dosen't work! Sima Baheri Phoenics 0 January 6, 2007 04:08
