Reverse outflow in vof,why???
Old   August 30, 2006, 14:20
Default Reverse outflow in vof,why???
Asghari
Hello all;
I am working on two phase flow modelling with condensation within a tube using the vof model. Scheme of implicit have been used for interface tracking between two phase at the steady state soloution.
I use outflow boundary condition type in outlet because i would like calculate drop of pressure within tube and therefor i can't use pressure outlet boundary condition and really outlet boundary has'nt no relation with external media.
I use a linear temperature distribution between 345k in inlet to 315k in outlet,but i faced with reverse flow in outflow boundary at duration of soloution process.
Can everybody answer me why this happened and how yo remedy this problem ?
Thanks in advance .
Old   August 31, 2006, 04:56
Default Re: Reverse outflow in vof,why???
Reginaldo
Which is the dimension of its domain? A solution is to increase the length of its domain in the main direction of flow.
Old   August 31, 2006, 07:26
Asghari
Ok,
length of tube is 1.154 m and tube diameter is 0.035m but i think reason for this problem is extending of liquid boundary layer to external zone ,therefor outlet is'nt placed in fully developed zone and length is'nt sufficient for this case. Do you certify this interpretation for this problem?
Old   August 31, 2006, 17:34
Reginaldo Cotto
I canīt imagine other solution. In my opinion you can be correct.
Outflow boundary Control Volume SIMPLE Help !!! Mizerable Main CFD Forum 4 August 22, 2011 13:00
Velocity outflow vs Pressure Outflow ramesh Siemens 1 January 9, 2006 01:12
mass flux correction at outflow boundaries Subhra Datta Main CFD Forum 2 November 24, 2003 13:11
outflow boudary condition in SIMPLE algorithm dallybird Main CFD Forum 0 March 6, 2003 11:55
Outflow Bocos Romuald Skoda Main CFD Forum 3 August 6, 1999 03:08
