Reversed flow on external aero problem
Old   August 21, 2006, 15:30
Default Reversed flow on external aero problem
Ben
Hi All,
I'm running an external case for a NACA0012 wing and I'm getting reversed flow at the flow field outlet. Do you think this is something I should worry about? I'm going by the assumption that its far enough away from the point of interest not to matter a whole lot. My flow field boundaries are 20c away all around the wing except in front where its 15c.
Cheers, and thanks in advance. Ben
Old   August 21, 2006, 16:05
Default Re: Reversed flow on external aero problem
shalu
check your gauge pressure value at outlet. if it is different at different outlet boundaries then u might get reversed flow. or if u ar specifying some non-zero gauge pressure at outlet keeping oprating pressure Atmospheric and in reality it should match with Atmospheric conditions then too u can get reversed flow.
Old   August 22, 2006, 10:05
Default Problem reversed flow on internal flow IC.Engine
Niki
when i saw this forum,i also have some question here about the scavenging simulation for two-stroke engine.When i run the modelling,similar problem like above problem (reversed flow),i try to change the value of control solution setting.I dont know how solve the reversed flow.hopes anyone can help me:.,this my email.,ir_nik@yahoo.co.uk
flow past abdominal aorta. Complex BC problem. ziemowitzima OpenFOAM Running, Solving & CFD 1 July 26, 2022 05:12
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
Reversed flow error with thin film heater MK FLUENT 1 February 12, 2009 10:26
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 16:52
